[postgis-devel] [PostGIS] #399: ST_CleanGeometry
trac at osgeo.org
Fri Jan 29 15:20:29 PST 2010
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by kneufeld):
Replying to [comment:4 pramsey]:
> MULTIPOLYGON is allowed to touch at one point:
> select isvalid('MULTIPOLYGON(((0 0, 0 1, 1 1, 1 0, 0 0)), ((1 1, 1 2, 2
2, 2 1, 1 1)))');
> isvalid
> t
> (1 row)
> Gets more complex as the rings start to share whole segments... in those
cases the boundaries should actually be dissolved... which is what the
buffer(0) case does.
Right, Mulitpolyons can touch at a point, but not on a line. You think
it's best to automatically dissolve bordering polygons? Yes, it is what
buffer(0) does, but buffer(0) was never intended to clean. What about
having a function parameter so the can user specify dissolve or not?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/399#comment:8>
