[postgis-devel] [PostGIS] #399: ST_CleanGeometry
PostGIS trac at osgeo.org
Fri Jan 29 15:34:04 PST 2010
  Reporter:  strk     |       Owner:  strk
      Type:  task     |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Comment (by strk):
 If you don't want to dissolve you can always ST_dump() and take each
 component apart,
 then re-combine the ones that *really* belong to the feature (as the only
 reason for not wanting a dissolve here would be to split the feature)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/399#comment:9>
