[postgis-devel] Shapefile to PostGIS Importer
Mark Leslie mark.leslie at lisasoft.com
Mon Jul 5 23:34:03 PDT 2010
It's been a while since I started this thread, but I've finally managed
to get it into my schedule.  I've pushed through the upgrades mentioned
(no budget yet for a port to wxWindows I'm afraid).  Attached is a
screen-cap.
Work has been done against the 1.5 branch, and checked into a spike:
http://svn.osgeo.org/postgis/spike/mleslie/current
I've also put up a zip for windows:
http://revenant.ca/www/postgis/postgis-loader-20100629.zip
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
Paul Ramsey wrote:
> I'm not actually that wedded to not changing the loader/dumper
> mid-stream. It's not something that other system components depend
> upon, unlike SQL signatures and so on, so I think we can reasonably
> work on that part of the code base pretty agressively.
> Another piece that needs work is a GUI take on the dumper, in
> particular one that takes a table as as commandline parameter (I'm
> thinking here of what running within at PgAdmin plugin context would
> look like.
> For 2.0 I'd like to look at swapping to another widget set. QT or
> WxWindows. I'm not so impressed with how well GTK+ is being maintained
> on non-Linux hosts.
> P.
> On Wed, Dec 16, 2009 at 7:31 PM, Mark Leslie <mark.leslie at lisasoft.com> wrote:
>> I'm chasing a bit of work to improve the gui import tool and I'm looking for
>> some feedback.  I'm thrilled to see how much has been completed in the last
>> few months, but there are three things I'd like to get in.
>> The first is to add the drop/append/create/prepare options.  Was there a
>> reason these were left off the gui?
>> Second is drag-n-drop capability for selecting files.  This is really my big
>> win here, but I'm still digging through docs to sort out how that's going to
>> work.
>> The third is a batch import capability.  This was actually off my radar
>> until Paul pointed me at QGIS' import tool, which is slick enough emulate.
>>  Once I actually get the time, I'll put my hand to some screen mocks.
>> I'm also not expecting to get a contract signed before christmas, so this
>> work is likely to happen after the 1.5 release, assuming the roadmap speaks
>> true.  The batch import is really the only thing on my list that feels like
>> it should not be in a point release, since it's a user facing change in
>> functionality.  That then pushes these changes back to 2.0.  Does it make
>> sense to assume I will be working towards 2.0, and just backporting the
>> first two bits?
>> Mark Leslie
>> LISAsoft
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100706/1967a7d6/attachment.png>
