[postgis-devel] Shapefile to PostGIS Importer
Paragon Corporation
lr at pcorp.us
Tue Jul 6 01:30:30 PDT 2010
Mark,
Thanks for these improvements. I love the ability to add multiple files at
a time.
Two issues I noticed off the bat using your windows version. Haven't tried
to compile my own yet.
1) If I try to use this as a plugin in PgAdmin III (which is the way we
normally use it), it crashes. Though doesn't seem to crash in stand alone
2) If we fiddle with the settings in the selected shapefile -- e.g. changing
the geometry column name or schema or table, sometimes these settings also
get thrown in the
DBF file character encoding field and then it gives an error from then on
invalid character encoding (geom or whatever we had typed is obviously not
a valid encoding).
3) Minor comment -- if you are going to be doing so much work on this, you
should probably throw your name in the credits too :)
Thanks,
Regina and Leo
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Leslie
Sent: Tuesday, July 06, 2010 2:34 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Shapefile to PostGIS Importer
It's been a while since I started this thread, but I've finally managed to
get it into my schedule. I've pushed through the upgrades mentioned (no
budget yet for a port to wxWindows I'm afraid). Attached is a screen-cap.
Work has been done against the 1.5 branch, and checked into a spike:
http://svn.osgeo.org/postgis/spike/mleslie/current
I've also put up a zip for windows:
http://revenant.ca/www/postgis/postgis-loader-20100629.zip
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61 Suite 112, Jones Bay Wharf
19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies http://www.ardec.com.au
http://www.lisasoft.com http://www.terrapages.com
Paul Ramsey wrote:
> I'm not actually that wedded to not changing the loader/dumper
> mid-stream. It's not something that other system components depend
> upon, unlike SQL signatures and so on, so I think we can reasonably
> work on that part of the code base pretty agressively.
> Another piece that needs work is a GUI take on the dumper, in
> particular one that takes a table as as commandline parameter (I'm
> thinking here of what running within at PgAdmin plugin context would
> look like.
> For 2.0 I'd like to look at swapping to another widget set. QT or
> WxWindows. I'm not so impressed with how well GTK+ is being maintained
> on non-Linux hosts.
> P.
> On Wed, Dec 16, 2009 at 7:31 PM, Mark Leslie <mark.leslie at lisasoft.com>
wrote:
>> I'm chasing a bit of work to improve the gui import tool and I'm
>> looking for some feedback. I'm thrilled to see how much has been
>> completed in the last few months, but there are three things I'd like to
get in.
>> The first is to add the drop/append/create/prepare options. Was
>> there a reason these were left off the gui?
>> Second is drag-n-drop capability for selecting files. This is really
>> my big win here, but I'm still digging through docs to sort out how
>> that's going to work.
>> The third is a batch import capability. This was actually off my
>> radar until Paul pointed me at QGIS' import tool, which is slick enough
emulate.
>> Once I actually get the time, I'll put my hand to some screen mocks.
>> I'm also not expecting to get a contract signed before christmas, so
>> this work is likely to happen after the 1.5 release, assuming the
>> roadmap speaks true. The batch import is really the only thing on my
>> list that feels like it should not be in a point release, since it's
>> a user facing change in functionality. That then pushes these
>> changes back to 2.0. Does it make sense to assume I will be working
>> towards 2.0, and just backporting the first two bits?
>> Mark Leslie
>> LISAsoft
>> Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
>> http://www.ardec.com.au http://www.lisasoft.com
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
