[postgis-devel] topology.sql distribution
strk strk at keybit.net
Thu Jul 8 02:47:25 PDT 2010
On Thu, Jul 08, 2010 at 10:26:50AM +0100, Mark Cave-Ayland wrote:
> However I think the following issues need to be resolved before we can
> consider this:
> i) Access to a specification (and no, I don't see paying for the
> specification as a valid option). Perhaps there are free drafts
> available, much like SQL/MM?
Version 1 (2004) and 2 (2005) seems available:
http://wiscorp.com/H2-2004-168r2-Topo-Geo-and-Topo-Net-1-The-Concepts.pdf
http://www.wiscorp.com/H2-2005-107r2-Topo-Concepts-The-Sequel.pdf
I belive draft version 3 is the one which ended up in the standard.
Not sure if that one is public.
> ii) Creating documentation for the PostGIS manual. I don't see how
> anyone can use it at the moment since it is entirely undocumented. We
> should probably mark it as beta quality too.
topology/README should be pretty much complete in describing what's
currently available. IIRC the postgis wiki should contain some more pages.
> iii) Maintenance. Who will be responsible for maintaining this part of
> the code longer term?
I'm willing to take this.
> Also, do TopoGeometries required their own PostgreSQL type in the longer
> term? Or is the specification simply a set of tables and joins?
There's a PostgreSQL type defined by SQL (TopoGeometry).
A factory function for it was in the standard:
   Topo-Geo and Topo-Net 3: Routine Details
   X.3.18(ST_CreateTopoGeo)
What was in the standard and what not seems to be documented in the
SQL file itself for each function/block (topology/topology.sql.in.c)
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
