[postgis-devel] [PostGIS] #473: Can't compile at all under Windows
trac at osgeo.org
Wed Jul 21 01:45:49 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: mingw |
Comment(by nicklas):
The geos issue might have a solution
[http://trac.osgeo.org/geos/ticket/365]
The postgis problem seems to be solved if <sys/param.h> is included in
lwout_wkb.c
Mark, I see you removed <sys/param.h> from some other file in 2009-03-16
according to the changelog with the comment that it isn't needed any more.
It seems to be needed for mingw, is there any problem with adding it?
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/473#comment:3>
