[postgis-devel] [PostGIS] #473: Can't compile at all under Windows
trac at osgeo.org
Mon Jul 26 04:21:43 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: mingw |
Comment(by mcayland):
Replying to [comment:3 nicklas]:
> The geos issue might have a solution
[http://trac.osgeo.org/geos/ticket/365]
> The postgis problem seems to be solved if <sys/param.h> is included in
lwout_wkb.c
> Mark, I see you removed <sys/param.h> from some other file in 2009-03-16
according to the changelog with the comment that it isn't needed any more.
It seems to be needed for mingw, is there any problem with adding it?
> /Nicklas
No, I don't think so at all. Try adding it and then build on
Windows/Linux/Solaris to ensure that there are no errors - if it looks
good then feel free to commit.
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/473#comment:4>
