[postgis-devel] [PostGIS] #536: Get rid of the STRICT on geography ST_Intersects
trac at osgeo.org
Wed Jun 2 05:36:59 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by anarazel):
I read this bug via Reginas Blog and can explain the issue at least a bit.
There are several conditions causing strict functions to fail:
* it uses other, non-strict functions. If it would get the strictness
would get lost. Imageine a unstrict function add(a, b) := coalesce(a, 0) +
coalesce(b, 0) and strict strict_add(a, b) := add(a,b). If strict_add()
would get inlined the promise of it returning NULL if any of its
parameters are NULL does not hold true anymore.
* some of the parameters are not used at all. Example: strict func_a(a,
b) := a. If that would get inlined the definition would change.
Those conditions are *completely* orthogonal to those imposed by
volatility - which imposes a different set of constraints.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/536#comment:12>
