[postgis-devel] [PostGIS] #536: Get rid of the STRICT on geography ST_Intersects
trac at osgeo.org
Wed Jun 2 06:02:04 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by anarazel):
Btw, volatile functions or non-volatile functions containing volatile
functions do get inlined as well if some conditions are met:
* the function itself is not less volatile than its contents (i.e. a
STABLE function containing a VOLATILE one
* no parameter *containing* a voltile function is used more than once.
(actually I think theres a bug here... It should also not inline if the
volatile parameter is not used at all)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/536#comment:13>
