[postgis-devel] dumppoints.sql regression test relies on special configuration
strk
strk at keybit.net
Fri Mar 12 06:58:04 PST 2010
On Fri, Mar 12, 2010 at 02:54:42PM +0100, strk wrote:
> Errors on make check:
> ! ERROR: stack depth limit exceeded
> ! HINT: Increase the configuration parameter "max_stack_depth", after ensuring the platform's stack
> depth limit is adequate.
> This is running the dumppoints.sql
Tried raising max_stack_depth from the default of 2MB up to 7MB
with same results.
Setting to 8MB resulted in a silent startup failure (pg_ctl
start doesn't complain but bakcend doesn't come up).
Can anyone confirm such behaviour ?
Environment informations:
PostgreSQL 8.3.8 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE Linux) 4.3.2 [gcc-4_3-branch revision 141291]
Postgis 2.0.0SVN - 2010-03-12 13:28:32
GEOS: 3.3.0-CAPI-1.6.1
PROJ: Rel. 4.7.1, 23 September 2009
CPU is about still at 100% during run.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
