[postgis-devel] dumppoints.sql regression test relies on special configuration
strk
strk at keybit.net
Fri Mar 12 07:03:22 PST 2010
Alright, this seems related to the change
in ST_NumGeometries, as the _ST_DumpPoints plpgsql function
makes use of that.
In particular, it relies on a NULL return from NumGeometries
to figure if a geometry is a collection or not:
-- Special case (MULTI* OR GEOMETRYCOLLECTION) : iterate and return the DumpPoints of the geometries
SELECT ST_NumGeometries(the_geom) INTO nb_geom;
IF (nb_geom IS NOT NULL) THEN
Doh...
--strk;
On Fri, Mar 12, 2010 at 03:58:04PM +0100, strk wrote:
> On Fri, Mar 12, 2010 at 02:54:42PM +0100, strk wrote:
> > Errors on make check:
> > ! ERROR: stack depth limit exceeded
> > ! HINT: Increase the configuration parameter "max_stack_depth", after ensuring the platform's stack
> > depth limit is adequate.
> > This is running the dumppoints.sql
> Tried raising max_stack_depth from the default of 2MB up to 7MB
> with same results.
> Setting to 8MB resulted in a silent startup failure (pg_ctl
> start doesn't complain but bakcend doesn't come up).
> Can anyone confirm such behaviour ?
> Environment informations:
> PostgreSQL 8.3.8 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE Linux) 4.3.2 [gcc-4_3-branch revision 141291]
> Postgis 2.0.0SVN - 2010-03-12 13:28:32
> GEOS: 3.3.0-CAPI-1.6.1
> PROJ: Rel. 4.7.1, 23 September 2009
> CPU is about still at 100% during run.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
