[postgis-devel] dumppoints.sql regression test relies on special configuration
strk
strk at keybit.net
Fri Mar 12 07:20:02 PST 2010
Fixed in r5426.
--strk;
On Fri, Mar 12, 2010 at 04:03:22PM +0100, strk wrote:
> Alright, this seems related to the change
> in ST_NumGeometries, as the _ST_DumpPoints plpgsql function
> makes use of that.
> In particular, it relies on a NULL return from NumGeometries
> to figure if a geometry is a collection or not:
> -- Special case (MULTI* OR GEOMETRYCOLLECTION) : iterate and return the DumpPoints of the geometries
> SELECT ST_NumGeometries(the_geom) INTO nb_geom;
> IF (nb_geom IS NOT NULL) THEN
> Doh...
> --strk;
> On Fri, Mar 12, 2010 at 03:58:04PM +0100, strk wrote:
> > On Fri, Mar 12, 2010 at 02:54:42PM +0100, strk wrote:
> > > Errors on make check:
> > > ! ERROR: stack depth limit exceeded
> > > ! HINT: Increase the configuration parameter "max_stack_depth", after ensuring the platform's stack
> > > depth limit is adequate.
> > > This is running the dumppoints.sql
> > Tried raising max_stack_depth from the default of 2MB up to 7MB
> > with same results.
> > Setting to 8MB resulted in a silent startup failure (pg_ctl
> > start doesn't complain but bakcend doesn't come up).
> > Can anyone confirm such behaviour ?
> > Environment informations:
> > PostgreSQL 8.3.8 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE Linux) 4.3.2 [gcc-4_3-branch revision 141291]
> > Postgis 2.0.0SVN - 2010-03-12 13:28:32
> > GEOS: 3.3.0-CAPI-1.6.1
> > PROJ: Rel. 4.7.1, 23 September 2009
> > CPU is about still at 100% during run.
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
