[postgis-devel] [PostGIS] #465: st_makevalid segfault
PostGIS trac at osgeo.org
Tue Mar 30 14:56:34 PDT 2010
  Reporter:  pramsey  |       Owner:  strk
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  osx, opensuse
Comment (by robe):
 strk,
 I tried to follow Paul's instructions here
 http://blog.cleverelephant.ca/2008_08_01_archive.html
 But having a bit of difficulty -- mostly cause I don't know what I am
 doing.
 I did this:
 cat clean.sql | valgrind --leak-check=yes --log-file=valgrind.log
 /opt/PostgreSQL/8.3/bin/postgres --single -D /opt/PostgreSQL/8.3/data -p
 5433 postgis
 But I guess cat is not the right command because I get a lot of syntax
 errors.
 The output of the valgrind is attached.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/465#comment:11>
