[postgis-devel] [PostGIS] #465: st_makevalid segfault
trac at osgeo.org
Tue Mar 30 15:16:41 PDT 2010
Reporter: pramsey | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords: osx, opensuse
Comment (by robe):
strk,
And for your info. Evidentally Paul is running 8.3 too if you look at his
gdb output up there he is running 8.3.8. What's odd now is that mine is
not crashing after I recompiled GEOS and PostGIS with CFLAGS="-g -O0".
But I am getting 2 regression failures now
One on measures and one on clean.
*** clean_expected Fri Mar 19 06:39:05 2010
--- /tmp/pgis_reg_15331/test_50_out Tue Mar 30 16:09:35 2010
*** 1,3 ****
--- 1,5 ----
+ NOTICE: Vertices lost in LWGEOM_GEOS_makeValid
RT|1|t|t|f
RT|2|t|t|f
RT|3|t|t|f
*** 23,29 ****
RT|17.1|t|t|f
PG|1|t|t|f
PG|2|t|t|f
! PG|3|t|t|f
SRID1|3
SRID2|3
SRID3|3
--- 25,31 ----
I first installed the clean.sql in my postgis db and then ran that single
command Paul had above
echo "select st_astext(st_makevalid(orig)) from clean_cases where caseno =
3;" | valgrind --leak-check=yes --log-file=valgrind.log
/opt/PostgreSQL/8.3/bin/postgres --single -D /opt/PostgreSQL/8.3/data -p
5433 postgis
Doesn't crash -- but valgrind gives
See next attached file. Its all greek to me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/465#comment:12>
