[postgis-devel] Database Architecture
strk
strk at keybit.net
Tue May 4 04:52:43 PDT 2010
On Tue, May 04, 2010 at 01:39:51AM -0700, OscarUK wrote:
> Hi forum users
> Please note I am a novice user.
> I wish to set up a very large PG database. For example, one 500x500km square
> had 60 million lines and 25 million polygons. However, at any one time users
> will be viewing or extracting only small areas, say 100m by 100m.
> Because of the database size, I intend to break this down into various
> schemas within a single database. Where I need to grab map extracts across
> schemas, I hope to script views (or queries) on the fly that return the
> required union between schemas.
> My questions are therefore:
> 1. Does this sound a sensible approach?
> 2. How can I create a second schema that contains all the PG functions?
> (When I create a new schema it contains no PG functions and I cannot work
> out how to 'get them in').
Postgis functions are tipically installed in the 'public' schema,
as long as you have 'public' in your search_path you should find them.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
