[postgis-devel] [PostGIS] #513: Can't upload dbf only with gui (without unchecking index?)
trac at osgeo.org
Wed May 5 07:30:36 PDT 2010
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by robe):
To add to this what makes loading dbf only cumbersome.
In the mask section -- we have only .shp and it automatically filters to
that when you first load the browse. Can we add .dbf to that filter.
Right now to load a dbf file that has no corresponding shp, I have to
1) browse to a shp file and select
2) Rebrowse and then pick the dbf (strangely going in a second time to
browse there is no filter set) so I am able to do this.
But as you can see the process is a bit convoluted.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/513#comment:1>
