[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
trac at osgeo.org
Sun May 9 08:10:19 PDT 2010
Reporter: loldrup | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone:
Component: postgis | Version: 1.4.X
Resolution: | Keywords: backend terminated exception
Comment (by loldrup):
Did a linux build of Postgres 8.4.3 including POSTGIS="1.4.2"
GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September 2009" USE_STATS,
and compiled with --enable-cassert
Changed postgresql.conf with the following options:
max_connections = 10
shared_buffers = 128kB
client_min_messages = debug5
log_min_messages = debug5
Ran the test again, starting at 09:34 - runnung stable without problems
(as expected on a linux build). At 13:34, and 1.889.000 samples the 5
backends was using between 109 and 123MB virtual memory each. At 16:20
JMeter came to a halt, probably another leak there.
I got a 3.9G log-file from postgres, but nothing special there - anyone
with a neural network that can grep for "non repeated things" in a GB
file?
I am not realy sure what can be concluded at this point apart, that there
is some leak in both platforms, and a to low shared_buffers triggers a
problem on win platform.
At 17:05 JMeter out controll, so I stopped it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:19>
