[postgis-devel] [PostGIS] #520: No check for different srid on operators when index is used
trac at osgeo.org
Mon May 10 05:36:03 PDT 2010
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by mcayland):
I must admit to be concerned at the time, but like you say now that the
indexable operators are built into higher level functions it doesn't seem
so much of a problem. So I'm not overly opposed to removing it to help
keep things consistent.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/520#comment:5>
