[postgis-devel] [PostGIS] #521: Can't compile PostGIS 1.5 against PostgreSQL 9.0 beta1 under MingW
trac at osgeo.org
Sat May 8 21:59:22 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Keywords: |
We were trying to get a build of PostGIS 1.5 prepared for PostgreSQL 9.0
beta1 and we seem to be having some difficulties.
Has anyone tried this. The error we are getting
/bin/sh.exe
c:/projects/pg/pg90b1/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/missing
perl ../utils/postgis_proc_upgrade.pl postgis.sql 1.5 >
postgis_upgrade_15_minor.sql
c:/projects/pg/pg90b1/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/missing:
No such file or directory
Not sure if this has to do with the pgxs change made in 1.5 or just a typo
we have somewhere. We are going to try to build on another box to see if
its just an error in our script.
On a side note -- since we seem to be stuck completely with PostGIS 2.0
(can't compile Geos 3.3 not PostGIS 2.0 under mingW) -- I'm thinking this
may be a message from above that we should just do a native VS build for
the 2.0 release. I'm hoping we can start tackling that in the next week
or so. The PostgreSQL 9.0 is going to support native Windows 64-bit and
with that said we'd have to start using msys64 or just compile under VS if
we don't want to force people to run PostgreSQL in 32-bit mode. Given
most windows developers seem to prefer Visual Studio/Express as well as
the cross boundary issues we have faced with libxml, seems we need to
move there eventually.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/521>
