[postgis-devel] [PostGIS] #521: Can't compile PostGIS 1.5 against PostgreSQL 9.0 beta1 under MingW
trac at osgeo.org
Mon May 10 05:47:56 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by mcayland):
On first glance, it's likely that the issue is due to using a Windows-
style path (C:\foo\bar) rather than an MSYS-style path (/c/foo/bar) in
MSYS.
I generally always build PostGIS against an MSYS-built PostgreSQL in order
to prevent these type of issues sneaking in, but maybe that is no longer
practical.
In terms of a VS build, the infrastructure is pretty much there. The hard
part is getting someone to maintain the independent build system, since it
can't be expected for non-Windows users to have to make alterations to
files that they can't really test. I know the PostgreSQL people try to get
around this by parsing the existing Makefiles with Perl scripts, which is
distinctly suboptimal :(
Ticket URL: <http://trac.osgeo.org/postgis/ticket/521#comment:1>
