[postgis-devel] mingw autotools
Paragon Corporation
lr at pcorp.us
Thu May 13 01:28:49 PDT 2010
+1
I like the idea of being able to produce a native VS compiled build and
still have available the goodness of what MingW/Msys almost did --- a fairly
consistent compile process across all Oses
And one set of configurations to worry about.
Mat,
my understanding is that that is what Cmake will provide. Is that correct?
The question is how much effort is it to get it going.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mateusz
Loskot
Sent: Wednesday, May 12, 2010 11:05 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] mingw autotools
On 12/05/10 03:13, Paul Ramsey wrote:
> It got more confusing, unfortunately. I had an older VM configured
> exactly to the old wiki page and the autotools there spit out a usable
> configure. So the problem (maybe?) is with moving up to the latest
> minor version of MingGW? So I don't know what the answer is except
> that building with MinGW is impossibly confusing. If VCC can offer a
> saner build situation it might be worth the time spent to just suck it
> up and go to a pure VCC build. Proj and GEOS already build in VCC as
> does pgsql so it's just postgis to do...
The meta-builder called CMake does the job well and for all (most)
environments. If CMake is of choice, I'll be interested to help.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
