[postgis-devel] [PostGIS] #527: Log window in shp2pgsql-gui should always append text to bottom of window
PostGIS trac at osgeo.org
Mon May 17 15:17:40 PDT 2010
 Reporter:  bmmpxf   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 (Using shp2pgsql-gui r5181 on Windows) Load the app and try testing the
 connection to a database.  The log displays some text.  Fine.  Now click
 somewhere inside the text (as if you were placing a cursor to insert
 something).  Now try testing the connection again.  The new log info will
 be output right at that cursor location, not at the bottom of the log.
 Sample case:
 Connecting: user=postgres passwoConnecting: user=postgres
 password=******************************* port=Connecting: user=postgres
 password=* port=54321 host=localhost dbname=OpenGeo
 Connection succeeded.
 rd=******************************* port=54321 host=localhost
 dbname=OpenGeo
Ticket URL: <http://trac.osgeo.org/postgis/ticket/527>
