[postgis-devel] [PostGIS] #663: shp2pgsql uses the wrong return type for pgis_getopt
trac at osgeo.org
Thu Nov 18 17:45:21 PST 2010
Reporter: ssinger | Owner: pramsey
Type: patch | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: |
pgis_getopt is defined to return an int (like a normal getopt).
However in shp2pgsql-cli and -gui the value is being stored as a char.
The compiler then promotes this char back to an int to compare with EOF.
The promotion of a char to an int with respect to negative numbers differs
based on hardware platform. On powerpc the ((char)-1) != -1
If we store the result of pgis_getopt as an int we avoid this issue.
Patch attached.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/663>
