[postgis-devel] [PostGIS] #662: ST_AddPoint is broken (was: Make POLYGONM geometry crashes server)
PostGIS trac at osgeo.org
Mon Nov 29 04:00:28 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Just retitling this since it's not POLYGONM at fault but as Paul
 rightfully suspected -- ST_AddPoint is just broken in 2.0.  I've excluded
 ST_AddPoint and ST_MinimumBoundingCircle from my tests for now since both
 use ST_AddPoint and also replaced geometries built with ST_AddPoint with
 static ST_GeomFrom... ones.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/662#comment:5>
