[postgis-devel] [PostGIS] #538: Problem with rendering PostgreSQL 9.0 beta ST_AsBinary
trac at osgeo.org
Sat Oct 2 07:39:16 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: 1.5.X
Keywords: postgresql9.0 windows |
Comment(by michaudm):
So, the bytea output format from PostgreSQL has changed.
My guess is that java code concerned by this change is
ResultSet.getBytes(columnIndex), which, I think, is the jdbc driver job.
From the following page, it appears the problem has been fixed in last
postgresql drivers.
http://jdbc.postgresql.org/changes.html#version_9.0-dev800
Could anyone with Postgresql 9.0 installed check if this new driver +
openjump fix the problem.
Thanks for your bug report on OpenJUMP bug tracker
Michaƫl, OpenJUMP contributor
Ticket URL: <http://trac.osgeo.org/postgis/ticket/538#comment:11>
