[postgis-devel] [PostGIS] #616: change with-gdal to with-gdalconfig
trac at osgeo.org
Sat Oct 23 08:05:17 PDT 2010
Reporter: robe | Owner: jorgearevalo
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
This sort of works -- I mean its picking up my gdal 1.8 even though that
is not anywhere in my path except at the configure, but it is showing this
error anyway. So I suspect this may be a bogus error.
configure: WARNING: unrecognized options: --with-gdalconfig
PostGIS is now configured for i686-pc-mingw32
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /c/projects/geos/rel-3.3.0/bin/geos-config
GEOS version: 3.3.0
GDAL config: /c/projects/gdal/rel-trunk/bin/gdal-config
GDAL version: 1.8.0
PostgreSQL config: /c/projects/pg/pg91/bin/pg_config
PostgreSQL version: PostgreSQL 9.1alpha1
PROJ4 version: 46
Libxml2 config:
/c/projects/libxml/libxml2-2.7.6release/bin/xml2-config
Libxml2 version: 2.7.6
PostGIS debug level: 0
-------------- Extensions --------------
PostGIS Raster: 0.1.6d
Ticket URL: <http://trac.osgeo.org/postgis/ticket/616#comment:3>
