[postgis-devel] WKB types: polyhedral surface, tin, triangle
Paul Ramsey pramsey at opengeo.org
Tue Oct 5 15:26:57 PDT 2010
Nevermind, I found it in the new "modularized" draft, along with a
raft of questions about inconsistencies.
- The WKT definition does not include a 2D version of polyhedral
surface, but the WKB one does.
- All the definitions include things like PolyhedralSurfaceM. M? WTF
does a 2-dimensional-with-measure polyhedron mean in the real world?
use case?
- Typo in the WKBGeometryZM entry indicates that PolyhedralSurfaceM is
a member (rather than ZM)
BTW, the numbers in the ISO draft do not match the ones you stubbed
into liblwgeom.h, which I think means you'll generate invalid WKB for
these entities?
P.
On Tue, Oct 5, 2010 at 3:20 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Olivier,
> I'm working on the new WKB parser/emitters and wondering where I can find the official type numbers for the polyhedral surface, tin, and triangle types? I see you have stubbed them into liblwgeom.h as 13, 14 and 15, but I'd like to see the appropriate specification document on how they are supposed to be structured.
> Thanks,
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
