[postgis-devel] Something wrong with build
Olivier Courtin
olivier.courtin at oslandia.com
Wed Oct 13 23:36:58 PDT 2010
On Oct 13, 2010, at 11:40 PM, Kevin Neufeld wrote:
Hi Kevin,
> make chunked-html jumps from 20 minutes to 1.
After fixing the few errors in DocBook code, doc process (r6077)
generation on my laptop is about 180s versus 150s without MathML dtd.
So not that a big difference...
Could you check again on your own to see if anything changed
about performance ?
Nota: there's still a warning on generation, related to
RT_reference generated in postgis_aggs_mm.xml:
Link element has no content and no Endterm. Nothing to show in the
link to RT_reference
Olivier
