[postgis-devel] [GENERAL] Getting FATAL: terminating connection due to administrator command
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Thu Oct 14 05:39:58 PDT 2010
If I do:
SELECT St_Buffer('0101000020E8640000000000000000F8FF000000000000F8FF', 50);
the PostgreSQL process leaves with:
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
The geometry looks like:
POINT(nan nan)
Regards,
Peter Hopfgartner
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Tom Lane <tgl at sss.pgh.pa.us> wrote--------
Subject: Re: [GENERAL] Getting FATAL: terminating connection due to administrator command
Date: 15.09.2010 21:34
>"Joshua J. Kugler" <joshua at eeinternet.com> writes:
>> On Wednesday 15 September 2010, Peter Hopfgartner elucidated thus:
>>> The server is a rather bare bone server for web mapping, so basically
>>> PostgreSQL/PostGIS, Apache, PHP, Tomcat and little other stuff. The
>>> Dell software was the only which did not come from
>>> CentOS/EPEL/argeo/in-house RPM packages. I've removed the Dell stuff
>>> completely, but the problem is still there.
>> Are you running out of memory and getting killed by the OOM killer?
>The OOM killer hits its victims with SIGKILL (kill -9), so we can rule
>that out as not matching Peter's symptoms. This is definitely an
>unwanted SIGTERM not SIGKILL.
> regards, tom lane
