[postgis-devel] [GENERAL] Getting FATAL: terminating connection due to administrator command
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Thu Oct 14 05:44:04 PDT 2010
Sorry, I missed some details:
this happens with
POSTGIS="1.5.1" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September 2009" LI
BXML="2.6.26" USE_STATS
and
POSTGIS="1.3.5" GEOS="3.0.1-CAPI-1.4.2" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS
Regards,
Peter Hopfgartner
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Peter Hopfgartner <peter.hopfgartner at r3-gis.com> wrote--------
Subject: Re: [postgis-devel] [GENERAL] Getting FATAL: terminating connection	due to administrator command
Date: 14.10.2010 14:40
>If I do:
>SELECT St_Buffer('0101000020E8640000000000000000F8FF000000000000F8FF',
>50);
>the PostgreSQL process leaves with:
>server closed the connection unexpectedly
>	This probably means the server terminated abnormally
>	before or while processing the request.
>The connection to the server was lost. Attempting reset: Failed.
>The geometry looks like:
>POINT(nan nan)
>Regards,
>Peter Hopfgartner
>R3 GIS Srl - GmbH
>--------Tom Lane <tgl at sss.pgh.pa.us> wrote--------
>Subject: Re: [GENERAL] Getting FATAL: terminating connection due to
>Date: 15.09.2010 21:34
>>"Joshua J. Kugler" <joshua at eeinternet.com> writes:
>>> On Wednesday 15 September 2010, Peter Hopfgartner elucidated thus:
>>>> The server is a rather bare bone server for web mapping, so basically
>>>> PostgreSQL/PostGIS, Apache, PHP, Tomcat and little other stuff. The
>>>> Dell software was the only which did not come from
>>>> CentOS/EPEL/argeo/in-house RPM packages. I've removed the Dell stuff
>>>> completely, but the problem is still there.
>>> Are you running out of memory and getting killed by the OOM killer?
>>The OOM killer hits its victims with SIGKILL (kill -9), so we can rule
>>that out as not matching Peter's symptoms.  This is definitely an
>>unwanted SIGTERM not SIGKILL.
>>			regards, tom lane
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
