[postgis-devel] 1.5.2 release ticket status - 2010-09-18
Paul Ramsey
pramsey at cleverelephant.ca
Sat Sep 18 12:40:05 PDT 2010
On Sat, Sep 18, 2010 at 8:52 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Hi all,
> [CC to Olivier]
> After some hacking today, here is where I think we are with a 1.5.2 release:
> **NEW BLOCKER**
> http://trac.osgeo.org/postgis/ticket/532 [PR]
> - The trunk commit is sensible based upon the ticket contents, but the 1.5
> commit looks totally wrong (it looks like the original version). I think it
> is just a case of removing and reapplying something similar to trunk, but
> I'd like a second opinion from Paul.
Re-applied. I'm happy with it.
> **UNSURE**
> http://trac.osgeo.org/postgis/ticket/522
> - I can't recreate this, but we should fix before a 1.5.2 release if it is a
> genuine bug. Maybe the newer version of shapelib fixes this which is why I
> don't see it in SVN?
I think you mis-referenced the ticket number, but you mean the
double-linked glibc failure. And yes, it's not in SVN, but it shows in
1.5.1, so I can only assume the shapelib update caught it.
> Existing outstanding tickets:
>>> http://trac.osgeo.org/postgis/ticket/522 [PR]
> I believe this is now not a bug, more that various other getopt()
> implementations have being clever things with out-of-order arguments. Just
> waiting for Regina to confirm, but I'm fairly sure this is FIXED.
>>> http://trac.osgeo.org/postgis/ticket/543 [MCA]
> This is starting to get quite hairy. I have some ideas, but they aren't
> going to be particularly quick to implement. I'd like to punt this to 1.5.3.
>>> http://trac.osgeo.org/postgis/ticket/572 [OC]
> Olivier, can you fix this before the end of the weekend? If not, I think
> this is something I can do tomorrow.
>>> http://trac.osgeo.org/postgis/ticket/513 [PR]
> This is FIXED, although there seems to still be an issue with selection
> filters. Let's punt to 1.5.3.
>>> http://trac.osgeo.org/postgis/ticket/527 [MCA]
> FIXED.
I am ready to run a release now, just say the word.
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
