[postgis-devel] [PostGIS] #603: shp2pgsql: "-w" produces invalid WKT for MULTI* objects
trac at osgeo.org
Sun Sep 19 08:16:31 PDT 2010
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: shp2pgsql |
Comment(by mwtoews):
I've tested with several other shapefiles, and I've confirmed this happens
with any simple line and polygon shapefiles. (But it does not apply to
point shapefiles).
The only possible way to avoid this bug and produce valid WKT is if the
polygon or line files are not multi- objects, and the "-S" flag is used
(this won't work with "foopoly" since it uses multi- objects).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/603#comment:2>
