[postgis-devel] [PostGIS] #603: shp2pgsql: "-w" produces invalid WKT for MULTI* objects
PostGIS trac at osgeo.org
Sun Sep 19 09:11:33 PDT 2010
 Reporter:  mwtoews    |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:  shp2pgsql  |
Comment(by pramsey):
 HWGEOM support is only required to load into pre-1.0 versions of
 PostGIS... are you testing this for completeness or for your own use? I'm
 willing to fix it in 1.5 if someone has a legitimate use for it, but for
 2.0+ it must be removed :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/603#comment:3>
