[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised, gserialized_get/set_srid () should be patched and typemod int too
trac at osgeo.org
Sat Aug 6 00:16:35 PDT 2011
Reporter: vince | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: invalid | Keywords: srid liblwgeom
Comment(by vince):
Paul,
I know about typemod, this is well documented in the source.
The knot is not here. THe main hurdle is that it is impossible to import
whatever raster with SRID 310024140, it seems. Anytime I try, the
generated extent SRID passed with the SQL transaction gets truncated to 21
bit, and the raster line is not imported, because the process reject the
extent geometry as bearing not the same SRID as the raster!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152#comment:5>
