[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised, gserialized_get/set_srid () should be patched and typemod int too
PostGIS trac at osgeo.org
Sat Aug 6 14:32:20 PDT 2011
  Reporter:  vince    |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  invalid  |    Keywords:  srid liblwgeom
Comment(by pramsey):
 Well, it sounds like the raster code needs a tighter limit on SRID number
 so the error is more explicit, but there's no way we're going to be able
 to store that SRID directly, it'll need to be a different internal number
 with a mapping to the external number.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152#comment:6>
