[postgis-devel] Common Code
Paul Ramsey pramsey at opengeo.org
Mon Aug 8 09:55:32 PDT 2011
We actually need two pieces of common code now.
- liblwgeom, which is already there, and Sandro is cleansing, is
common to geometry, raster, loader dumper, even the documentation
builder!
- postgis, which is what we currently call geometry/geography should
be an agnostic place were we have some utilities for caching call
information between calls (used by projection, prepared geometries,
etc) and other code that is common to all types, but has a dependency
on pgsql. In an "ideal" world, we would have: ?
./liblwgeom
./postgis/common
./postgis/geometry
./postgis/geography
./postgis/raster
./postgis/topology
./postgis/geocoder
./docs
Or something like that. In any event with raster in the pool the need
for a separated out utility library of pgsql-dependent things goes up.
P.
On Mon, Aug 8, 2011 at 9:47 AM, Bryce L Nordgren <bnordgren at gmail.com> wrote:
> On Mon, Aug 8, 2011 at 9:56 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> On 06/08/11 18:57, Sandro Santilli wrote:
>>> Note that all postgis users (raster, postgis, cunit) are linking against
>>> the static (not shared) library.
>> I've just taken a look at this, and I think that if we're going to switch
>> from static to dynamic then we might as well just do it. Otherwise we're not
>> going to get the testing we require.
> I had issues trying to link to a not-yet-installed dynamic library. It
> appears that (on Linux anyway), moving a shared library after you've linked
> to it is bad karma. I think his solution of linking against a static library
> for all postgis consumers and offering a shared library for outsiders is the
> only workable solution I can see.
> http://trac.osgeo.org/postgis/ticket/1058#comment:8
> It may be best to record problems/progress on ticket #1133. While it
> involves the creation of a library of "common postgresql-aware code", the
> exact same issues are encountered in both cases.
> Bryce
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
