[postgis-devel] [PostGIS] #1155: Can't compile PostGIS 2.0 under mingW
trac at osgeo.org
Tue Aug 9 02:00:35 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords: windows mingw
Comment(by mcayland):
Correct. Just for the record, linking under Windows is order-sensitive
(resolution from left to right) due to the way in which Windows resolves
symbols within library files so this should be the correct fix.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1155#comment:13>
