[postgis-devel] [PostGIS] #1156: Tiger geocoder README (and unix loader suggestions)
trac at osgeo.org
Fri Aug 12 09:56:01 PDT 2011
Reporter: forkandwait | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Attached is a slightly edited version of the README, with any major new
text in CAPS.
Besides stylistic things, I broke paragraphs by 2 newlines and re-wrapped
the text to be 80 character or less lines (except for some code). Now it
"looks right" when you open in it emacs, and it didn't before.
I also added instructions on outputting the script to a file from psql
(basically "\a \t \o foo.sh" -- but look in the text for details)
Also, I added text that recommended that the generated script be edited
with "set -e -u" at the top to make it debug easier (this is basically
like "use strict" in Perl -- otherwise the script keeps running even if
wget can't find a server, for example). This change should be folded into
the SQL code, by someone who knows how that works.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1156>
