[postgis-devel] [PostGIS] #1156: Tiger geocoder README (and unix loader suggestions)
trac at osgeo.org
Fri Aug 12 13:37:42 PDT 2011
Reporter: forkandwait | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by forkandwait):
In my README I suggested that "set -e -u" be added to the generated script
because it will make the script stop if there is an error.
While this is great advice, I get errors when constraints are created that
already exist if I run with "set -e", and the script just blows past them
otherwise. There *may* be a problem with the generated code that "set -e"
is uncovering (or it might be running the loader on a totally fresh DB
would work, while I am trying to restart it).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1156#comment:1>
