[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Sat Aug 13 08:53:08 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Sadly did not work after autogen.sh configure. Still same problem.
gcc -g -O2 -Ic:/projects/pg/pg84/include/POSTGR~1/server
-I/c/projects/proj/rel-4.6.1/include -I../liblwgeom -DDLL_EXPORT -DPIC
-Wall -Wmissing-prototypes -c -o lwgeom_transform.o lwgeom_transform.c
In file included from c:/projects/pg/pg84/include/POSTGR~1/server/c.h:854,
from
c:/projects/pg/pg84/include/POSTGR~1/server/postgres.h:47,
from lwgeom_transform.c:13:
c:/projects/pg/pg84/include/POSTGR~1/server/port.h:17:19: netdb.h: No such
file or directory
c:/projects/pg/pg84/include/POSTGR~1/server/port.h:18:17: pwd.h: No such
file or directory
c:/projects/pg/pg84/include/POSTGR~1/server/port.h:372:24: netinet/in.h:
No such file or directory
c:/projects/pg/pg84/include/POSTGR~1/server/port.h:373:23: arpa/inet.h: No
c:/projects/pg/pg84/include/POSTGR~1/server/postgres.h:48,
c:/projects/pg/pg84/include/POSTGR~1/server/utils/elog.h:41:1: warning:
"ERROR" redefined
C:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/windows.h:52,
from
c:/projects/pg/pg84/include/POSTGR~1/server/pg_config_os.h:21,
from c:/projects/pg/pg84/include/POSTGR~1/server/c.h:87,
from
C:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/wingdi.h:313:1:
warning: this is the location of the previous definition
make: *** [lwgeom_transform.o] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:11>
