[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Sat Aug 13 10:52:35 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by bnordgren):
Replying to [comment:11 robe]:
> Sadly did not work after autogen.sh configure. Still same problem.
Just to confirm, you did manually edit configure.ac to apply the patch in
the above github link, correct? (...prior to the autogen.sh and configure)
If so, I'm not sure I understand why the extra directory was not picked
up. We may need to grab someone with more experience with autoconf, as I
am limited to copying and pasting promising looking snippets. :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:12>
