[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Sat Aug 13 12:23:58 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 You need AC_CANONICAL_HOST for $host to be defined. Try adding an 'echo
 "-----"$host' line to see what you get.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:13>
