[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Tue Aug 16 22:23:12 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Okay for 8.4 that hack makes it compile to .dll. make check gives me a
can't find libgeos_c.dll but sure that's probably easy enough to fix.
Haven't tried to see if I have the same issue with loading into PostgreSQL
as I do with 9.0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:23>
