[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Wed Aug 17 03:40:40 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I confirmed my 8.4 postgis.dll is also no good -- get same error when I go
to install in a fresh db
ERROR: incompatible library
"C:/projects/postgis/pg/pg84/lib/postgis-2.0.dll": missing magic block
HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1158#comment:24>
