[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Wed Aug 17 12:44:53 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Well I  think I made some progress.  I added PG_MODULE_MAGIC to
 postgis/lwgeom_geos.c
 right before the datum stuff (Line 23).
 And got this far:
 whole bunch of create function stuff successful and then
 breaks in
 psql:c:/projects/PostGIS/trunk/regress/postgis.sql:2175: ERROR:  could not
 find function "transform_geom" in file
 "c:/projects/PostGIS/trunk/regress/00-regress-install/lib/postgis-2.0.dll"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:28>
