[postgis-devel] [PostGIS] #1161: move gserialized_gist to libpgcommon
trac at osgeo.org
Wed Aug 17 19:29:35 PDT 2011
Reporter: bnordgren | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
I was getting a missing symbol error when attempting to run the raster
regressions. `lwgeom_pg.c` uses utility functions from gserialized_gist.
Also, `gserialized_gist` uses utility functions from gserialized_gist_nd.
The required functions have also been moved to gserialized_gist.
The attached patch applies to r7757, although you may have to manually
remove `postgis/gserialized_gist.c`. Again the problem appears to be the
$Id$ string.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1161>
