[postgis-devel] [PostGIS] #343: History Table Enhancements
PostGIS trac at osgeo.org
Fri Aug 19 07:50:37 PDT 2011
 Reporter:  pimpaa          |       Owner:  pimpaa
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis         |     Version:  trunk
 Keywords:  History Tables  |
Comment(by pimpaa):
 Hello Regina,
 It's not a problem. I'm not sure if I mixed versions, but here worked just
 fine. I'll run some tests and I'll look for the issues you've mentioned,
 specially 2 and 3;
 There is a test script included. Did you see it? It setups a dry run and
 tries to test all functions.
 Thanks for the support.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/343#comment:15>
