[postgis-devel] [PostGIS] #1165: Selectivity extimation of && operator
trac at osgeo.org
Sun Aug 21 11:27:23 PDT 2011
Reporter: edoardopanfili | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by edoardopanfili):
I redo a fresh postgis 2.0.0SVN 7774 installation. After installation I
did an hard-upgrade to update my db then a "vacuum analyze". If it is
usefull I can post the single steps.[[BR]]
All the part (potgres 8.4.8, postgis 1.5.3, postgis 2.0.0SVN 7774) are
compiled
in Mac OS X 10.7.1 using (gcc -version) [[BR]]
i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build
5658) (LLVM build 2335.15.00)[[BR]]
the plan for the query in postgis 2.0.0SVN 7774 is:
Sort (cost=32.66..32.73 rows=29 width=944) (actual
time=89371.383..89371.389 rows=76 loops=1)
Sort Key: cartellino.id
Sort Method: quicksort Memory: 74kB
-> Hash Join (cost=12.27..31.95 rows=29 width=944) (actual
time=1780.217..89371.271 rows=76 loops=1)
Hash Cond: (cartellino.idspecie = principale.id)
-> Nested Loop (cost=0.00..9.80 rows=605 width=899) (actual
time=7.109..89348.115 rows=18370 loops=1)
Join Filter: _st_intersects(cartellino.the_geom,
confini_regioni.the_geom4326)
-> Seq Scan on confini_regioni (cost=0.00..1.25 rows=1
width=1473539) (actual time=0.014..0.018 rows=1 loops=1)
Filter: ((regione)::text = 'UMBRIA'::text)
-> Index Scan using cartellino_punto_geom_4326 on
cartellino (cost=0.00..8.29 rows=1 width=899) (actual time=0.118..100.269
rows=32200 loops=1)
Index Cond: (cartellino.the_geom &&
-> Hash (cost=8.28..8.28 rows=319 width=57) (actual
time=0.595..0.595 rows=74 loops=1)
-> Index Scan using i_specie_nome_specie_like on specie
principale (cost=0.01..8.28 rows=319 width=57) (actual time=0.064..0.526
rows=74 loops=1)
Index Cond: ((esterna_nome(ibrido, proparte,
(genere)::text, [...] (cultivar)::text) ~<~ 'Quercut'::text))
Filter: (esterna_nome(ibrido, proparte,
(genere)::text, [...] (cultivar)::text) ~~ 'Quercus%'::text)
Total runtime: 89371.646 ms
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:2>
