[postgis-devel] [PostGIS] #1165: Selectivity extimation of && operator
trac at osgeo.org
Mon Aug 22 14:08:17 PDT 2011
Reporter: edoardopanfili | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by robe):
The plans look pretty much the same except in the 2.0 the cost estimate
for this part is much worse than 1.5. I assume you already did a vacuum
analyze of the tables.
-> Index Scan using i_specie_nome_specie_like on specie
principale (cost=0.01..8.28 rows=319 width=57) (actual time=0.064..0.526
rows=74 loops=1)
Can you remove the ST_AsGML just to rule out a memory leak in that
function and tell me what the timings are without that.
Also would it be possible to provide us the data. If its private, you can
send me download info at lr at pcorp.us and I'll test it against my 1.5
and 2.0 to see if I see similar issues or if its specific to your
platform.
Thanks,
Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:3>
