[postgis-devel] [PostGIS] #1176: [raster] Two raster ST_Intersects
PostGIS trac at osgeo.org
Sat Aug 27 15:40:10 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by bnordgren):
 I don't suppose I could twist your arm into helping with the generation2
 raster iterator for this, could I? I have most of the "toolbox" written,
 meaning the interfaces as well as "providers" for geometries and rasters.
 I also have "wrapper" providers, to do things like represent the object in
 a different projection. And don't forget the spatial and value "operator
 primitives". Really, the next step is to write the thing which evaluates
 the inputs at fixed intervals (e.g., grid cells)...Almost there...
 The code is on github: https://github.com/bnordgren/postgis
 My branches are messy because I was learning how to use git, but the
 relevant code is on 'ri-gen2-arch'.  If you want to build it, you have to:
 export PYTHON=python
 ./configure ...
 otherwise the configure will fail.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1176#comment:2>
